Permabanned
- 17 Sep 2014
My understanding is that it is a hardware related way of controlling a fan. What is the point of this over just using software?
Does it require a 4 pin connection on motherboard? My motherboard only has 2 headers which are 4 pin, one is called case the other CPU. I have a passive CPU cooler so I assume its ok to use the CPU header for a case fan?
If so, if I am going to have 4 fans, I assume I just use a splitter on each one making 2 from each 1 header.
Finally, what are the basic rules of in and out flow? Should they be equal? Thanks
