- 30 Jul 2006
A Google search says that X17-22376.exe is "An executable file for installing Office applications. Once you install the Office applications on your computer (if required) you may safely delete it.". This seems to suggest (to me) that it may actually be MS Office.
On someone else's PC I want to reinstall MS Office 2010 Pro which has developed a fault but he doesn't have the installation media - he does have the Product Key. The X17-22376.exe file is 672 MB in size.
