I’ve bought the factal design meshify c case, it only comes with 2 120mm fans so looking to get couple more for the front. So was wondering if it’s better to get a couple more of the factal fans that come with the case or is there recommend cases fans for better cooling? If replacing the fans is it better to go with 3x 120mm or 2x 140mm(the case supports 3 120mm or 2 140mm in the front)? I’m not bothering with rgb so only looking at standard fans.
I’ve also got the Celsius s24 aio aslo from factal design, I’ll be installing the radiator in the top as I have the evga 1080ti ftw which means I can’t install it in the front. Does changing the fan have a major improvement on the temps or not worth the extra cost?
