What fans you running in Enermax CS-527?
10 Apr 2006
Edinburgh
I really like this case in my new system,i got 2 80mm fans to fit in back,one was a blue led akasa and other a coolermaster.
The cm is really quiet (1250rpm) but the ak is the noisiest fan in the machine,spinning at 2500 rpm.Should i take back the ak for another cm? or would the cooling be worse?.
I see there is space for 80-120mm fan that sits at bottom front which i presume would be blowing on the hard drives? worth getting another?
As is just now on warm day with side panel on cpu is 30 and mb is 35 (which gets to about 39)
Cheers
Al
Your temperatures seem just fine, quite low and certainly nothing to worry about.
You should get the noisey fan replaced for something you think is quieter. :)
Should not adversly affect the cooling, if it does just stick in another fan on the free mounting then. :)
Should make little difference if any to your temperatures.
