what fps
12 May 2005
derby
What fps should i be getting in metro 2033 dx11 all maxed at 1680x1050.
17 920 at 3.6
ati 5970.
The reason i ask is because it sems crap
Not to sure tbh, seems to play alright on my PC. Q6600, 5870 same res you are running. I could check tonight when I get in to see what I am getting on average.
Try turning off (I think it's called) 'Depth of Field'. That should help. There might be another setting, can't recall it though, bound to be one of the lighting options.
Yep, thats the other one I was trying to think of, depth of field, do try it with that disabled as well
Metro is the new crysis when testing it maxed out..
