What FPS..
I haven't played MLL or Sim City, but for 2033 you'll have a very good playing experience provided you don't crank everything up to the full.
Metro 2033 & Sim City should be fine, you'll have troubles in Last Light though. Presuming you mean to play maxed @ 1080p+?
2033 would work well on high, try and disable the advanced DoF though, that's an FPS killer. Battlefield 3 will run medium-high, can't tell the difference between ultra and those settings tbh.
