What fuse do you run?
30 Jul 2005
Midlands
All of my power supplies are 600w or less so i run 3amp fuse in the cable. Iv seen people shove 13amp in everything lol. So what do you guys run?
The fuse is to protect the cable. Typically 'kettle' leads are fine with 13 amps.
Your 600W PSU could draw up to 750W depending how efficient it is, maybe 3.3 amps, but such fuses tend not to blow until a bit over their rated capacity.
Iv seen 5a common in our work computers.
Also as you say its to protect the cable but if something goes wrong with the device its always best to have it fused for the power draw in mind and not the max the cable can take that way lower rated fuse can react faster and pop.
Also I didn't know this but if fuse pops within 1 year you can take it back to Toolstation for replacement. Very odd since i thought fuses that pop in general use was considered to be normal and not something anyone would claim warranty for lol
PC and Monitors (even CRT) normally come with a 5amp but the higher end Corsair have bigger lead and a 10amp fuse, there is a few threads on topic on it somewhere as I searched it before.
I went rummaging around box of cables and checked the ones currently in use. All my old kettle cables came at 13amp fuses, although I'll admit that all of them were from 2011 or before. My latest Seasonic Fanless 700w came with a 5amp fuse. My first one I noticed.
13A usually. Less if the cable itself isn't rated for 13A.
Fuses can take from seconds to hours to blow for anything less than a complete short-circuit. Quick enough to stop the cable from catching fire, but far too slow to protect the electronics inside the PSU.
Every single lead that came with high end PSU's from 2003 till now like Antec, Enermax (when they when good) and Corsair had 5A fuses fitted, the AX1600I has 10A in a bigger lead never run a 13A fuse in your PC or monitor lead.
