^ A 10A fuse will blow when used with a 3KW kettle.![]()
edit: before anyone tells me 10A fuses don't exist, they do... they're not very common though. Manufacturers should be using them for 'kettle' leads but I guess 13A's are easier to source...![]()
3 or 5 at most - However if you like a big bang when your PSU expires then by all means go for a 13A.
Makes no difference to how big a bang it makes!
Fuses are only there to protect the cables, nothing else! Wont save your PSU or your PC from a mains voltage fault as they're inherant disconnetion time is too long to prevent damage should the fault occur across the transformer... In theory (and mostly practice) if your house is compliant with recent wiring regs your RCD/RCCB/RCBO on your consumer unit should go out before a plugtop fuse has time to blow in the event of a PSU failure.
Correctomondo!Merely saying a fuse is provided to protect the cables from overload and fire, not to protect the connected equipment nor the userAs far as british standards go 13a and kettle leads is just fine
