I think curtain poles look a bit naff screwed to wood. Track looks ok but poles look best on the wall.
^ This.
Holy crap! I did not realise all the implications of putting a pair of curtains up.
Only because it's something you've not tried before.
I've done it several times and can manage it with minimal thought quite quickly... even quicker if the Mrs doesn't insist on 'helping'!!
To answer some of the questions, it's an external wall, and it's a big window, so the curtains are big too, and heavy with it. I think it's plaster and brick, but I'm just guessing.
Is it brick outside?
Get a Cable Finder and make SURE you're not going to drill through anything vital. Good brands can be had for under £30, which is a small price to pay against 240V zapping through you... plus you can reuse it in future projects!!
Make sure the screws and rawlplugs are long enough to support that kind of weight. The fixings that come with the rail should be good enough, but if in doubt get some longer ones.
Lastly, these things usually have a measuring guide and a drilling template. Measure it up, then re-measure, then re-measure a third time. Do this as much as it takes to get consistent results, because you can only drill it once!
So I need to get a wooden batten, fix that to the wall (i.e., drill holes, insert plugs, screw in), then fix the curtain rail to the batten?
Your call. I've personally never done this.
Can I just use any old drill or do I need something in particular?
If you're drilling into brick, you'll need a masonry drill bit of the appropriate diameter.
You'll also be better off with a drill that has a Hammer Action (it will have a little hammer icon) and multiple speeds - The former helps go through brick. The latter increases speed as you press the trigger in further, so you can start slowly and be sure of drilling right on the mark.
I'd suggest at least an 18V drill, especially if you're going cordless. There's a nice Black & Decker one for a good price at your local 'well-known gardening & DIY superstore'.
