What gfx card for £150?
17 Mar 2012
Hi, guys my first post here, but long time lurker.
Im after a new graphics card for my system:
Mobo: Gigabyte Z68X-UD3P-B3
CPU: i5 2500k with freezer13 Pro cooler
Ram: 8gb corsair vengeance
Current GPU is: GT210
PSU: 850w
HDD: 750gb
I have £150 to spend i could MAYBE go to £170 if there was a massive hike in performance.
Ill be using it for gaming mostly, maybe with a bit of 3D work if i fancy it.
Game like skyrim, MW3, Deus Ex : Human Revolution, Dragon Age 2, Star craft etc...
So far i have been looking at the:
gtx 560 OC £155
http://www.overclockers.co.uk/showproduct.php?prodid=GX-057-ZT&groupid=701&catid=1914&subcat=1341
gtx 460 SOC £120
http://www.overclockers.co.uk/showproduct.php?prodid=GX-171-EA&groupid=701&catid=1914&subcat=1830
GTX 560ti OC £170
http://www.overclockers.co.uk/showproduct.php?prodid=GX-168-EA&groupid=701&catid=1914&subcat=1810
Is there anything else i have missed?
I did see that the gtx 480 is back in stock and i was tempted but i was put off by the noise and heat.
Thanks, James.
+1 for the GTX 560Ti - For that price you won't find a better card.
One thing may be worth considering is waiting until next week - as the ~£200 HD 7850 2GB should come on sale on monday.
This is a nice card if you can afford the extra, and it may cause a drop in the price of a HD 6950 2GB (which is currently £200 with a free game).
May I ask what the make and model number of your 850W PSU is?
Thanks for the replys.
Another thing i forgot to ask was, is it worth my waiting for something new to come out, i was reading about the GTX 6xx cards are out soon, or is that only the high end card and wont really effect the price range of the low-mid cards?
Also i know next to nothing about AMD cards, if the HD 6950 2GB drops sub 200 then i may be temped, what GTX card would be a comparable card to it?
The release date for the new Nvidia Kepler series is a bit unclear AFAIK - there are a few rumours now that the GTX 680 will be released late next week (OCUK did say they are getting their stock on next week - but can't start selling them until official release by nvidia). I'm not sure if the initial release will be just the top-end GTX 680 - or other cards like the GTX 660 (which may be in your price range).
As for the HD 6950 2GB, here is a comparison with the GTX 560TI. Also, bear in mind that the HD 6950 2GB has double the VRAM of the GTX 560TI 1GB - which (depending on your resolution) will be of use in some newer games which make good use of lots of video memory as well as high-resolution texture packs (both mods and official DLC).
I game at 1920x1080
I have read that when gaming @ 1080 you dont need more than 1gb vram but i have no idea how true that is, i think ill wait untill the new 7850 comes out and hope that the 6950 drops in price if not i guess ill just go for a OCuk 560ti
Does that sound like a good plan?
Sorry missed the question at the end, my PSU is a cheep PSU: NOV-PSU800, and i was mistaken its only 800w
Oh cripes ! :(
TBH, before you spend ~£160-170 on a new high-power graphics card you should strongly consider replacing that £39 "800W" PSU with something of quality. I would recommend a PSU like this one at the minimum.
Oh cripes ! :(
I agree 100% tbh i hate this thing, after only a month the fan started to make loads of noise, i asked the devil for a replacement and they said i had to send it off leaving me without a PSU for a week.
Will that 550W be powerful enough to run my system with a new gfx card?
+ say another 1TB HDD and a SSD in the future?
Thanks, James
Can you remove that competitor name please in the PSU description.
And again in the above post.
And fully star out the swear word.
Aye, best remove the OCUK competitor name, as it is against the rules. Instead perhaps just refer to that PSU as the "NOV-PSU800".
It does sound like it isn't a keeper, have the shop offered you a refund? If so i would take it - from the specs (one PCIE power connection, no 80plus rating) it doesn't seem like a good one and not worth risking a power hungry and expensive system on.
As for a 550W - yes a good quality 550W power supply (i.e. one that can stably and reliably deliver the required power with little ripple and good regulation) will happily power a system which uses an overclocks i5 2500K and a HD 6950/GTX 560Ti/HD 7850 graphics card.
Excellent thanks very much for your help, i think ill go for the 650w OCZ PSU just to be on the side of caution. I cant wait for this new stuff now. :D
