Right, I need a new GFX card. My 1900xtx died and currently I'm using a 6200le
eek
. What do you guys reccomend?
The only games I play are CS Source/Quake 4 if ever. Might look into TF2 as well.
This is my system Spec
Opty165 @2.5ghz
Asus A8N-E
2gb Mushkin Ram(what speed i have no idea)
Antec 450WPS(i think)
2 sata drives.
i want something that can do the same as my XTX in terms of power. Cheap as Poss too
Cheers!
Looking forward
eek
. What do you guys reccomend?The only games I play are CS Source/Quake 4 if ever. Might look into TF2 as well.
Opty165 @2.5ghz
Asus A8N-E
2 sata drives.
.Cheers!
Looking forward
IMO go with the pro, will suit your rez better with games that have massive rez in the textures and such thanks to the 512mb of memory, if you upgrade your monitor, at least you will have the GFX memory for games that will need it. Performance is on par and beats the GTS in most games if you overclock it, others on here have confirmed XT speeds are easily got on the pro.
