Thanks for looking
I'm doing a build at the moment and the specs are:
Intel Core i5 2500k
Asus P8Z68-V Gen 3
Corsair Vengeance 8Gb (Will be 16gb)
XFX 650w Core Edition
Zalman Z9 Plus Case
EDIT: 1920 x 1080 res
Basically I'm doing a cheap-ish build for Uni which will have plenty of power and will be futureproofed etc...
I cant decide on graphics card. I will do some gaming, not heavy but I want to be able to play games on high detail, maybe even some on max but still have the power so that I can still play games to come in a years time (even if not at highest settings)
I've looked at the 560Ti and this seems a good card. With regards to budget I'm not really sure so for now I'm gonna say between £150 - £250, but I don't wanna get a £250 card and end up not using it. I wanna be able to game, but it doesn't need to cost the earth if you get what I'm saying.
Also I need to have a quiet card, under load a bit of noise is fine, but ideally I want a card that will be whisper quiet when idling
Intel Core i5 2500k
Asus P8Z68-V Gen 3
Zalman Z9 Plus Case
