What GFX to run 27" (U2711) and 24" (2407W) pls???
20 Oct 2004
London
Hi Guys,
My 19" has just died a horrible death. I use to run the Dell 2407W along side it.
Basically I need a new monitor and I was thinking of getting the Dell U2711, and running that with the 2407W.
I currently have a GTX 275, presumably that cant run them both. So what GFX would you recommend? Dont really do much gaming, with the exception of Eve and Starcraft 2.
I do use Photoshop, and Video Editing here and there.
Meds
Well i have the same 27" and a very similar 24". I have two gtx 580 but i got them mainly for bf3. As you dont list that game just one would surfice i imagine easily. Or even a 6950 would do the job well
Thanks for the replies, I dont have a budget tbh, just dont want to spend money needlessly :)
Its physically capable of it yes, and those games arent particularly demanding so you may be OK, I wouldnt rush into buying a new card you may not need
Doesnt the U2711 need a dual DVI or something? I thought that would mean I would need to use both the outputs for the one monitor, meaning I dont have one for the 2407.
Or am I being a noob??
Yep, DVI dual is just a different cable and is standard among higher end systems.
*patiently waits for surveyor to post pi of different DVIs*
:D
I'm having a busy night on the forum.
So many problems, so little time.
A dual link cable/connector has more connections for greater bandwidth.
Here you go for an image of the different types:
The Dell U2711 will come supplied with a dual link DVI-D cable.
Both DVI connectors on the GTX 275 are dual link so there's no problem running the Dell U2711 from one.
