im looking for a reliable, silent, fairly inexpensive (dont need to rackmount it or anything!!) gigabit switch for a home network in a new house.
i'll need a 5 port GbE switch as i have a server which will be stored in the basement and i'll then need to run a single long run of cat6 upstairs to an 8 port GbE switch which will extend the network to the bedrooms upstairs.
any suggestions?
whats the maximum length of cat6 i can use for running from the 5 port down in the basement to connect to the 8 port which will be located upstairs? just trying to figure out how to route the cable and how much i have to work with.
im thinking i should go this route instead of a single 16port GbE switch in the basement as i would need to run lots of longer length cables to the upstairs machines which would be a hassle having them tucked away as opposed to a single (maybe an extra one for backup) cable.
if i have "server" and "pc1" on the 5port and "pc2" on the 8port. is there any speed hit on pc2 as i have to go through both switches to get to the server whereas pc1 will be connected to the same switch, if that makes sense?
any suggestions?
