I've just fixed my Moto 5GS (used hot air to soften the glue attaching the screen to the frame) - there was a loose connector inside after the phone was dropped.
The screen sticks back down okay but of course it's not as good as it was so it's likely to start to lift up after a while.
What glue should I use to stick it down better?
Note: must still be possible to remove the screen with heat after applying whatever glue I use (just in case I ever need to take it apart again).
