Rust is very much CPU bound, that CPU may struggle with it.Hi, I have £450 to spend on a gpu and currently have a ryzen 7 1800x and 3200mghz ram, what do you guys recommend? This will be used to mainly play rust if you guys know much more about that. Thanks
Try to lend 75 pounds try for a 3070Ti at 2pm
Or wait on that well known site for other 3060ti about 1hr after that
As they dropped 3060ti ,3070, 3080's 3090 last week at 315pm
After the 3080Ti launch![]()
I've got my finger on the trigger
Yeah you and me both !!I've got my finger on the trigger
Yep me too. I've got my eyes on 3090 FE
At 450 RRP you can only buy a 3060 atm, but I would really recommend you to try to buy a cheap RRP 3070, the difference is huge and it would be about £100 more.
A Palit 3070 gaming pro is fairly good and about 550 RRP if you can find it …
However I do not know Rust …
Did they stop producing 3080FEs now?
At the RRP price they are such good value, it makes almost no sense to sell at this price except for improving her corporate image.More than likely. Though i'm guessing based on the Ti launches
Yeah jump on board !Can I join this trigger club ?
