what gpu so i go for
3 Jul 2007
Rochdale/whitworth
need a gpu for around £100 used what should i be looking at
i was thinking gtx1070-1080 or are they to old for my sons first pc he plays mainly fortnight on his Xbox the pc will have a i5 10th gen and 32gig ram
I'd look at a 1660S or TI for that sort of money, around 1070 performance but a little newer so better support and hopefully more shelf life.
You might be able to find a second hand AMD 6600 or 5700(XT) if you can stretch/are lucky and those would be a good deal faster.
Just be wary of anything that might have been mined on, and make sure his PSU is up to snuff.
Have a look on the members market, you might luck out and can always put in a request, you'll generally get much better and safer deals compared to somewhere like Ebay/Facebook MP.
It would be worth pushing your budget even another £50 imho. It'll increase the time required before you need to upgrade again. He's likely to broaden his horizons a bit when playing on pc.
I will keep an eye out on there I have till the 25th of May to build it
