what graphics card for my new build
22 Dec 2007
can anyone help me make the decession for a graphics card its bin a while since my last build so not quite sure ive read good reviews on the 8800gt overclocked versions (zotac) & is also well priced but also the new 8800gts g92 is coming down in price? many thanks chaps:)
Well firstly i would say it isn't really worth paying the premium for a pre-overclocked GT, its probably better to pay just a little bit more and get a GTS.
However depends on your budget, if you want to spend £200+ get a GTS, if you want to spend more in the £170 range, get a stock GT and overclock it yourself using rivatuner - takes 10 mins. The difference between a GTS and an overclocked GT is virtually nothing however you can push the GTS a little further itself.
