OcUK's x1950pro 512mb should play those games fine, £85.
Hey, i only want to play games like
- Counterstrike source
- Battlefield 2
- Oblivion
- Rainbow Six
- Doom 3
On high settings. How much do i need to spend and what gfx card you recomend?
Thanks, Ben.
As long as you're only playing games on a single monitor then the 1950pro will be more than enough.
Oh and that's with everything on full, also for bf2 i run everything on high, no lag whatsoever, haven't used fraps with it so i can't give you the exact stat.Well i have a 8600GT and in the CSS video stress test i get 200fps average. I'm sure that would be enough for you?Oh and that's with everything on full, also for bf2 i run everything on high, no lag whatsoever, haven't used fraps with it so i can't give you the exact stat.
at 1680x1050 the X1950Pro will start to struggle, sure it will be ok for CSS and BF2, but if what about future games? that card will struggle more than say a GTS.
