What graphics card
18 Oct 2002
Cambridge
My brother in law has a PC I built for him a while ago. It's pretty basic, Ryzen 3400g with 16gb RAM. He was using the on-board graphics. He now wants a graphics card for it. He bought himself a Samsung M70B 4k 60 hz monitor. What's the cheapest card to get 4k gaming?
Unfortunately the cheapest card to get 4k gaming is not cheap. At all.
Ball park? What would you suggest as an alternative?
Edit
Looks like 3060ti is over £400 and pretty sure that's out of his budget.
It's within budget apparently. Will a 3060ti be ok with Sea of Thieves and Overwatch at medium to high settings?
Edit
Not sure why i was looking at 3060ti, 4060ti is more affordable.
Ryzen 3400G with a 4k monitor interesting pairing.
Yeah the 4k monitor was a new addition. I know the cpu is a massive bottleneck but don't want to upgrade the whole thing. If I can get medium to high settings at 4k then that will be a bonus but understand I might have to drop down to 1080p. At which point I'm guessing a 4060ti is a bit overkill?
He would have been better off starting with the CPU/GPU and then moved on and bought a monitor that suited. But I know you knew that...
:D
If you're dropping down to 1080p it kinds defeats the object of a 4K monitor?
Looking at current set-up and likely future budget, a better fit would have been a 144HZ 1440p monitor, it's not a 4K card - be careful of the 8GB VRAM it's already considering obsolete - however in a very limited selection of games it may well be fine for a while, just don't expect great perfoance for years in AAA titles to come.
He originally just wanted a cheap pc to play some basic games on.
Yeah, I can see what happened...
He's probably going to end up playing at 1440p on a 4K monitor, also Overwatch is better played at low resolutions and tons of FPS, not maxed out 40FPS at 4K...Sea of Thieves of 5 year old game on 4K monitor, why?
Best bet would be send it back, and have a rethink.
In HUB's results with Ampere, RDNA 2 performed better with weaker CPUs, so if you're looking at a 4060 Ti, then I'd consider the 6700 XT (as close to £300 as possible) for older games and esports they're capable of 4K, especially with upscaling from 1440p.
