just 'attepted' my first overclock, nothin extreme just raised the 266 FSB to 333 (to get 3 GHz) according to this forum this clock should be easy to get.... NO
so, what went wrong
(The info below is just me expressing my fustration)
heres what happened
basically, pc switchs off after saving bios then switchs its self back on and just gets stuck at the first screen that says preess TAB for POST and DEL for bios but it wont let me choose either, ctrl+alt+del dosn't work either. so now its time to reset the cmos, this took me me much longer then it should have since i was using the wrong jumper for a while starting to panic because i thought i may have 'destroyed' my rig
but i found the 'real' jumper later 'hidden' under the graphics card GRR 'bad mobo designing there' (had case 'upright' when doing this), making it very hard to insert the jumper pin. incase anyone is wondering, I did check the manual BUT it contains info for 2 different layouts for my board but the 'larger' part of it is for the other version of this board (so its showing me the wrong layout when it points out where things are), and thats my story. RAGE complete, back to happy
everything is back to stock now, put me off oc'ing for a while, not too bad since the Q6600 at stock is GREAT and handles everything i throw at it, i just wanted a little more 'BANG' for me 'BUCK' lol, and to run my CPU in sync with RAM.
so, what went wrong
heres what happened
