what happened
2 Oct 2004
N.W London
Spec as per in sig, using vista..
I have dual display which work independantly from each other...
I unplugged both monitors earlier as I was fixing a different machine so needed to plug in 1 monitor...
Afterwards plugged both back in, and now my system refuses to go into windows, if it does it the screen suddenly goes blank...
That said it boots fine in safe mode..
I did receive the "run32dll.error" when I booted normally so I removed all nvidia drivers and reinstalled them...
Why does my screen go blank when booted normally? after a few seconds?
Please help
Hope I explained things clearly enough
Press F8 while the PC is booting up. Select "Enable VGA Mode" and then set your resolution. You should be good to go after that. I've not had the problem personally but a friend brings his system round now and again so we can play poker and have a drink online and we have to do this every time he uses my spare screen.
