Hi Guys,
I installed RivaTuner 2.24 to have a go at Overclocking my 9600 GT graphics card.
I went into customising the system settings where you can adjust the slider bars to alter the clock speeds.
When I clicked the check box to enable adjustments of the speeds, it asks to detect stock settings and recommends a reboot. I go ahead and click on reboot in the dialogue box and my computer restarts.
Now, as soon as I get into windows and everything is loaded, the screen goes black, the monitor is still receiving a signal because it will say otherwise. I wait a few minutes and hit the reset button on my tower, the exact same thing happens again.
I hit reset once more and this time when windows loads, the screen goes completely blue, pink and then a mix of the two for a few seconds and then stops with everything seeming normal however everything is slow as *@%$! There is even a delay between me typing the keyboard and the letters appearing on screen.
Any ideas?????????????????????
My Spec:
Windows XP SP3
AMD Athlon 4400+
2 GB RAM
Nvidia 9600 GT (still at stock settings)
My Spec:
Windows XP SP3
AMD Athlon 4400+
2 GB RAM
