I went home for the weekend and drive back to brighton yesterday, just before i left i topped up the water level in the coolant tank but i forgot to screw the top on properly. I didn't realise until i was in brighton as it wasn't running that hot.
I managed to boil off all the water and as soon as i arrived in brighton, i popped the bonnet and topped the water back up and didnt drive it till later on last night.
Now when i got up this morning to go to work, i noticed that the temp guage seems to be higher than normal (it's always over-read but this is higher up the scale). It seems to be going up and down as in the same range as it did before, but its just doing it higher up the temp guage, eg:
It used to sit between 100 / 110 degree's on the guage (should be 90 which is exactly horizontal) and never went above it, now it sits between about 105 and 115/120 degree's which puts the temperature warning light but the fan doesn't kick in for a couple minutes, when it does the temp guage seems to hold steady at around 120 with the temp light still on.
I've had a load of stuff done to the cooling system recently aswell, new radiator, thermostat, fan switch.
Is my engine overheating or have i fried the temperature sensor which the dash guage read's from?
