What, I have no picture??
29 Aug 2006
I have just bought this system :
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail
Antec Super LANBOY Aluminum Super Mini Tower Case - No PSU
Akasa AK174CB-4BLB 120mm Blue LED Fan
Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB
Microsoft Windows XP Media Centre 2005 Edition - OEM - 1Pk
MSI 975X Platinum PowerUP Edition (Socket 775) PCI-Express DDR2 Motherboard
ATI Radeon X1900 ***Crossfire/Master Edition*** 512MB GDDR3 (PCI-Express) - Retail
Hiper HPU-4B580 Type R 580W Modular ATX2.2 PSU - Blue (CA-006-HP)
G.Skill 2GB DDR2 LA PC2-5400 (2x1GB) CAS4 Dual Channel Kit
Everything appeared to be cool and everything was compatiable so i bought it and put it together. I started it up and everything had power (Fans were wering, optical drives flashing, HDD spinning). I then connected my monitor and it said there is 'no signal'. So i checked the connection and everything was in place. The Mobo defin had power because cpu fan was spinning, so i tried it again, same problem occured. I then moved the card down to the Secondry express slot but same problem.......
Can anyone plz help???
PS. dont know whether valueable but i had to connect monitor to graphics by an adapter which converts the digital signal of the graphics to analogue.
Cheers James
I presume you had seated the graphics card correctly into the slot and plugged in the power cable into the card itself?
Also check the cable going to the monitor is plugged properly into both the graphics card and the monitor.
Yep, i have connected the power into the card and the board and tryed them alternativley and yes the cables are in both the moitor and the card correctly...
Keep tryin!!
