What inflation device is in your boot?
5 Aug 2004
My yellow Halfords double foot pump has sprung a leak, it's useless now and I've been looking on the rainforest and Halfords for a new footpump and nearly every pump has too many negative reviews to ignore.
Before I buy any of them I thought I'd check here first for some research.
Just a cheap electric pump that plugs into the ciggy lighter. Not sure where its from dad bought it ages ago but it does the job the few times I've used it.
This one and it is very fast compared to my old Michelin one....
No you can't mention it, don't try to be clever - Armageus
I've got a green slime pump and slime bottle thing from the rain-forest. Works fine for me. In fact, I have 3, one for each car.
I have this one and it had never let me down in the few years and countless times I have used it despite being treated fairly roughly! I bought it for around £6 when there was an offer on a while back
I got one last year, after reading a few reviews, and i got a Ring Digital Air Compresser, it is really good
Yellow double barrel halfords foot pump for me, ive used mine for years and years and when it does break i'll probably just buy another.
I seem to use it quite a bit for various things so an electric one would be pretty useless to me most of the time so i'll stick with a manual one.
I bought a Ring RAC635 that's been okay.
It's small and fast with auto shutoff when it reaches the pre-set pressure. I bought this one because it's very simple to change the desired pressure. My previous pump was a pain once I changed to a car with different front/rear pressures.
I've got the same one in my car, it's OK but was struggling to do 60 psi into the space saver when I needed it. On the flip-flop I used it to inflate a paddling pool that was about 1.5m diameter and about 30cm tall and had no issues with that (just took a while). I thinks it's from ****** but not sure as my dad bought me it.
I stole the Honda pump that came with the FN2 and have that, works well enough if need be though I do also how actually have a spare
Some cheapo one from Halfords, works ok, I use a separate pressure gauge though to check pressures..
