What is 5-5x5+5?
Following BODMAS the answer should be -25 as BODMAS has to be done in that order. However many folks on here are doing BODMSA instead to end up with -15 although there is the claim that you don't have to stick to AS order you just have to go left to right with AS which would mean using either AS or SA :D
Anyway,
5-5x5+5 = ?
5-(5x5)+5 = MULTIPLY FIRST - BODMAS
5-(25+5) = ADDITION SECOND - BODMAS
5-30 = SUBTRACTION LAST - BODMAS
or
5-(5x5)+5 = MULTIPLY FIRST - BODMSA
(5-25)+5 = SUBTRACTION SECOND - BODMSA
-20 + 5 = ADDITION LAST - BODMSA
Giving -25 or -15 but there's a few ways of doing it which will give different answers so, in the end, the real answer is the lessons we learnt on our journey to find the answer! :D
Following BODMAS the answer should be -25 as BODMAS has to be done in that order, too many folks on here are doing BODMSA instead to end up with -15 although there is the claim that you don't have to stick to AS order you just have to go left to right with AS which would mean using either AS or SA :D
Anyway,
5-5x5+5 = ?
or
Yeah...I was a bit stumped reading through but that's what I did!
Y'all need to re-learn some kiddy maths if these confused maths takes are genuine and not just adding to the earlier bad takes for the LOLs:
https://www.bbc.co.uk/bitesize/guides/zsnycdm/revision/1
Anyway,
5-5x5+5 = ?
or
BODMAS still requires you to go from left to right. SOHCAHTOA on the other hand all I remember was the way to remember it "Silly old Hitler couldn't advance his troops over Africa". Can you imagine that being taught in school now as a way to remember something. :P
BODMAS still requires you to go from left to right. SOHCAHTOA on the other hand all I remember was the way to remember it "Silly old Hitler couldn't advance his troops over Africa". Can you imagine that being taught in school now as a way to remember something. :p
Hitler is still fair game, carry on.
Anyway,
5-5x5+5 = ?
or
It's not addition then subtraction, It's addition AND subtraction completing from left to right. The answer is -15.
Indeed.
Brackets first
Orders (i.e. Powers and Square Roots, etc.)
Division and Multiplication (left-to-right)
Addition and Subtraction (left-to-right)
This is probably the biggest flaw in the BODMAS mnemonic - it doesn't actually mean you have to do DMAS in that order.
(DM and) AS have equal precedence and should be carried out in the order they appear.
This confuses a lot of people who only vaguely remember it from school.
What is 5-5x5+5?
It's a deliberately poorly constructed string of numbers and operators :p
This is the best answer. It's better to write clearly than to rely on everyone remembering an arbitrary order with an inaccurate mnemonic.
