Mite be wrong here, but if a car has a turbo has it not got more chance of passing an mont without a decat compared to a N/A without one. As turbos give out less emissions?
What? My impreza gives off something ridiculously high like 280g/km.
Illegal for use on the road.
It seems you need to research your opinions before you go off saying that they're fact.
If the de-cat pipe raises emissions above the relevant levels for the vehicle as stated in the Motor Vehicles(Construction and Use) regulations, then it is an offence to drive it on the road. However, the mere absence of a catalytic converter is not in itself an offence AFAIK.
then they give you a seven day fix it !!
Not rocket science.
Of course, if you are pulled over by the DVLA/VOSA, and they decide to do a full emissions test there and then, you could fail!
But, you could also fail if you do have a cat in place, if it's degraded or has fallen apart!
The act of fitting a decat pipe in itself is not illegal - but you will have to bear in mind that if you do get pulled over for a spot-check, you could fail the emissions test.
I know that, but the Biggles said that a decat was illegal on the road, without any qualifier.
It's not the first opinion he's stated as a fact which is wrong.
He also stated in another recent thread that cars record how long you have driven without the cat and the police fine you per mile - which sounds distinctly on the outer edge of the believable to me.
I have a 100-cell in the downpipe myself. But my understanding of using a cat in the cat-pipe (on newages) or centre section is that it doesn't work as effectively, so seriously tuned cars could still fail an emissions test? Not a problem on cars with normal power though.
M
I thought that all cars registered 93> HAS to have a cat in order to pass the MOT?
