What size is the fan?
You may be able to remove the cover / fan and replace them with an Arctic F12 TC or F9 TC fans by attaching it with zip-ties. The fan can be bigger than the fins as long as it can sit on them. Slip the temperature probe between fins and card and it will be speed controlled by the heat of GPU.
