I have since release had a set of Logitech Z5500, which I only used the Toslink, but today I bought a Rega DAC-R and on the back it has multiple Toslink inputs as well as a USB Input.
Which is the better connection to use the USB or Toslink? A mate says DAC only works properly via USB. But my answer to that is that they are both digital so shouldn't be a difference
Thanks
Thanks
