Hi, one of my computers is playing up at random.
Spec is as follows:
Abit Nf7-S
Mobile XP 2500 @ 2500mhz
1G of Corsair XMS 3500
Hercules Radeon 9800XT with cat 7.7
etc
All of a sudden, without warning the graphics will turn into coloured blocks and vertical lines but it is still possible to see the normal screen under the weird shapes. This is normally when on the internet which is what I do mostly.
Pressing the reset button will not remove it, it needs the comp to be turned off properly for things to be returned to normal.
Interestingly you can see the strange patterns as you first start up the comp, long before XP starts loading.
I have tried reseating the graphics card and it is still the same.
All ideas welcomed!!
Cheers, PeterT
Spec is as follows:
Abit Nf7-S
etc
Cheers, PeterT
Hope it didnt dribble
