I've been having a few problems with smearing and after cleaning the windscreen and the wipers today, I went for a drive and it started to rain.
Whilst at low speeds, it didn't smear and the rain wiped away quite well. I was ecstatic. This was until I went down a dual carriageway (still, whilst it was raining) and noticed all of the marks I had previously removed were now present and I could hardly see where I was going.
Now, if I active the windscreen washer jets it will initially clear these smears and everything will be fine for a few minutes until the smears gradually start to come back and repeat. I have noticed that when the rain lands on the windscreen, it sticks and doesn't roll anywhere (if that makes sense) - it almost looks as though the raindrops are of a light whiteish colour on the screen, as if they were diluting something on there.
I topped the washer fluid up not too long ago, so I don't think it could be that. The windscreen and wipers were initially cleaned at a hand car wash, I have also tried to clean the windscreen and wipers with standard glass cleaner but the smears continue to appear.
As a general observation, when I wipe the smears with my finger, black gunk comes off.
I am thinking of:
Any ideas as to what might be causing this? Looking to narrow it down rather than doing all of the above or if the cause is much simpler and easy to solve.
tldr; smears on both sides, when activating washer jets it gets rid of the smears for a while but they come back after a few minutes, seems to occur mainly when driving at speed, when wiping the smears with my finger black gunk comes off.
I am thinking of:
- Cleaning the windscreen with a clay bar in case this is just the result of lots of dirt/oil that's accumulated which isn't really visible to the naked eye and cleaning the blades again
- Replacing the washer fluid again and then cleaning the screen/blades again too
- New windscreen wipers (though why would they clean the screen properly when activating the washer jets - perhaps the blades are in fact worn and the washer fluid provides the extra lubrication they need to function?)
