Its supposed to be AMD's answer to Nvidias G-Sync, damn spoilt it now.
This, G-Sync and Free-Sync is a variable refresh rate system, it stops ghosting and screen tearing.
The difference between the two is with NV G-Sync you need a new screen, a compatible screen that has £100 worth of hardware built in pushing the price of the screen up by that much.
With AMD's Free-Sync what that £100 hardware add-on does is done locally on the GPU its self, including all HD 6000 Series GPU's and obviously all later GPU's.
You still need a new screen, a compatible screen, but there is no need for the £100 add-on hardware.
Misleading much?
You're making it sound like there's a cost in addition to the new monitor on the G-sync side whereas it's an implicit 'cost' on both sides making it directly and easily comparable. I hope that isn't intentional misleading.
http://www.extremetech.com/gaming/1...-reinvent-gaming-or-vanish-as-a-niche-productThe verdict, therefore, is that while G-Sync doesn’t matter for every game, it can make a dramatic difference in certain titles, particularly if you’re upgrading from a 60Hz panel. Asus estimates that the VG248QE, which normally runs about $280, will go for $400 with a G-Sync kit built-in. That’s a substantial cost adder, particularly for a TN panel — Anandtech hopes that we’ll see the technology built into 2560×1440 displays, where it might also make more sense for FPS reasons. G-Sync works best in games where the frame rate hovers between 30 and 60 fps. Modern high-end cards have less trouble at 1920×1080, but take heavier hits at 2560×1440.
Not sure if any Non laptop screens have the required hardware for Freesync atm either so its also likely to be a added cost
So what screen could i buy and run freesync on atm for my desktop?
No need to start in an argumentative tone
G-Sync does add costs to the screen.
Yes Humbug we get that but that isn't what I originally interjected on.
What I was saying is that the way you worded your original post was that there was a cost ON TOP of the cost of the new monitor.
So atm there isnt a Free sync screen available then?
We have to wait for firmware/hardware new models?
If it has the Hardware inside it, there is.
Oh my days.
So yes, the cost of the new G-sync model is 'all in' right?
The cost of the 'only existing' G-Sync Monitor WITHOUT G-Sync is $280, the same screen WITH G-Sync is $400.
. That's my opinion now on it at least. Could be wrong though and time will tell.
.Not sure if any Non laptop screens have the required hardware for Freesync atm either so its also likely to be a added cost
so don't go out and buy one).
