I've been attempting to overclock my EVGA 1070 SC (Both Afterburner and X), manually and through setting curves. I had heard setting curves gave you better clocks though, so I thought after I found a good manual clock I'd switch to a curve and see if I could get a better one.
Well... what's going on? Something seems off for sure.
Stock
+175/+550 Manual
2217/+550 Boost
2240/+550 Boost
2443/+550 Boost
Yeah. You heard that last one correctly. X (GPU Z was confirming the readings) was reporting a stable 2443 throughout the entire benchmark, without dropping once at 1.093v. Fans were blasted up to max to keep the temps at 45c.Of interest is how while the boosted scores are lower than the manual clock, the minimum FPS goes up with each one. This (is basically what the boost settings in X looks like (the extra before 1.093 was me trying to get the thing to crash).
So it is quite obvious that something is being reported wrong, as the manual clock goes quite a bit higher in Heaven and crashes on the core long before GPU boost does.
I've got no ideas on what the hell is going on. It's like I've missed something but I'm unsure as to what, exactly. I'm using the latest version of Precision X (downloaded it today after trying Afterburner), and setting the offset with GPU Boost to the same as the manual offset (+175) resulted in lesser performance compared to the manual offset.
Posted in a few other places but haven't seen any real definitive answers so I'll try here too.
Stock
+175/+550 Manual
2217/+550 Boost
2240/+550 Boost
2443/+550 Boost
