what is hehda.exe?
14 Aug 2003
cyberspace
Hi,
I was looking at program that want internet access in zone alarm ant noticed hehda.exe in C:/user\appdata\local\temp\hehda.exe.
is this a virus? Should it be allowed internet access?
I have ran AVG anti virus and spybot and nothing has come up-pls help
http://www.malwarebytes.org/
Get some MBAM loving going on. Install, update, full scan. Rinse repeat until no infected items. Will take hours. Chuck in some TDSS killer for luck
http://download.cnet.com/Kaspersky-TDSSKiller/3000-2239_4-12684178.html
Nuking an Windows Vista/7 system and reinstalling takes a couple of hours, just depends how many programs and how good your backup regime is decides if this is worth it or not
Make sure your Java runtime version is up to date, along with any browsers you use and their plug ins
Looks like a nasty. Get Combofix Malwarebytes and the free 30day trial of Kaspersky internet security and run them all one at a time to remove any nastys you have. When clean go get Secunia PSI personal and run that, update software as advised.
