What is inverted ATX?
Basically, the motherboard is flipped 180 degrees so that it sits on the other side, upside down. ATX motherboards are still used. Makes no difference at all, just make sure the case is good, ignore the orientation.
I think there both the same, just the case opens on the right hand side instead of the feft, and the motherboard is installed upsidedown.....Inverted :)
Like Thus, I Know bad example...:( lol
Am I right in thinking it's made so that the CPU is at the bottom where the case should be coolest? (Heat rises)
