Hi,
This might seem like a lame question but what exactly is a 'Modular' power supply?
For example what is the difference between these two: -
Corsair HX 850W ATX Modular SLI Compliant Power Supply
and
Corsair TX 850W ATX SLI Compliant Power Supply
When would you require a 'Modular' one against the non-modular one?
Thanks & Regards,
Andrew
and
Thanks & Regards,
Andrew
) PSU could supply 4 sata drives, the others had to use a PCI-e to SATA adapter on the cable - leaving the already long PCI-e cable with an extra extension and clogging the place up.
