Sometimes you are able to shade in a resistor of a voltage controller circuit to reduce the resistance across it...this will result in a higher GPU voltage.
How you do it depends on the card you have. It should never be done without use of a DMM.
Basically it's physically modding your graphics card to make it quicker.
We used to have to overclock CPUs this way, before manufacturers started writing decent bios'.
read the techpowerup article though because the resistor is a bit easier to shade...although it does take a heck of a lot of shading sometimes.
