What is Pin Tilting?
14 Sep 2006
Dorset Apple Cake
I just sold an old P4 CPU to someone on Fleabay and they messaged me to ask that I wrap it well (which I have) and Pin Tilt it.
Any ideas? :confused:
TYIA :)
Ah I see :)
I have got a jewelry box with the padding still in that I can push the cpu into.
Would that be ok?
The OEM P4's and Athlons's CPU's came in a small box with polyurethane foam inside.
The pins pushed into the foam on the bottom.
Foam on the top stopped the CPU from moving around.
A small box with a couple of pieces of sponge should be OK.
