as my other thread on the grafics side of upgrading my system for CAD rendering and gameing. i have been recomended to upgrade my E6850 dual do a quad such as the Q9550 and overclcock it to 3.6+ GHz is possible with air cooling but couldnt i get the Q9650 and clock that?? any help to a beginner to overclocking would be great.
the speck of my machine is:
Core 2 Duo E6850 @ 3.00Ghz
4 GB of ram (looking at 8 gig and 64bit xp)
gigabyte x38 mobo
ATI Radeon 2600 Pro
now the new spec to upgrade to is as folows also:
q9550 ( or similar) Oc'd
8 gig ram : (Corsair 4GB DDR2 XMS2 Dominator PC2-8500C5 TwinX (2x2GB) Supplied with Airflow Fan (TWIN2X4096-8500C5DF))
xp 64
4870 ( to look to crossfire if needed later on)
what are you thoughts
regards
chris
gigabyte x38 mobo
ATI Radeon 2600 Pro
xp 64
regards
chris
