Hi just wondering what are considered 'normal' safe temps for a quad core cpu? as mine currently idles at around 45-55C :S
ive heard similar problems from peeps with the 8800gtx in their system and thought maybe its this generating mental heat and boiling up my system so just wondering can anyone tell me their temps who has a similar system to mine (check sig) just for info i have an akasa eclipse case with an akasa amber 120mm intake and same exhaust, and a scythe ninja rev b cpu hs with the stock 120mm fan attached.
cheers
cheers
