What is the advantage of an enterprise SSD versus a consumer SSD?
1 Nov 2007
England
I'm starting to think about my new build (not actually going to build it for a year or so but I need to start thinking about components so I can save up for them) and was wondering about whether I should get consumer grade SSDs or enterprise SSDs.
I'm thinking of getting 2 NVMe PCI-E SSDs (one for Windows and one for Linux) and was wondering what the real difference is between the enterprise SSDs and consumer SSDs? If I wanted better reliability (even at the cost of a little bit of performance) would I be better off with the enterprise PCI-E SSD?
Consumer SSDs are optimised for small disk queue depths and Enterprise SSDs are optimised for large disk queue depths (things like databases, mail servers). Have seen a few benchmarks where consumer SSDs outperform enterprise ones at small queue depths (the typical usage you will give it in a PC). Sort of like single-threaded performance vs multi-threaded.
Ah, that makes sense. Thanks.
I forget the term but they also have higher number ofspare sectors to replace failed ones.
Oh, over provision.
Oh, over provision.
So in general they last longer then? Hmm. I was thinking about putting 4 SSDs into a RAID 10 array. Sounds like enterprise drives might be what I am after all.
Yes, but how long do you want them to last? Consumer ones at consumer usage tend to last quite a while.
Depending on the price difference and cost of convenience a properly setup multi-disc RAID you can just swap out individual drives as they fail and might not be much of an advantage over using cheaper consumer drives.
Oh, over provision.
I've always struggled with this term Over-Provision in regards to SSD and storage in general.
I feel its really an under-provisioned as its smaller volume than the actual disk size, but I guess at the block size you could consider it as over-provisioned as it could live on any of those blocks. :eek:
Thin provisioning of storage, allocating smaller volumes than the actual disk space can provide can lead to over-provisioning whereby if all thin volumes expanded fully you'd potentially not have enough space if you over-provisioned your volumes.
I guess its not the first time we have contradicting terminology.
