what is the best 780ti non-reference card?
1 Aug 2014
york
what is the best 780ti that ocuk sell?
or is it just personal preference or is it some are better for some situations and some not?
i will be using two 1440p monitors, gaming on one and browsing on the other
literally will be buying a new build so my specs would be
YOUR BASKET
1 x EPIC POWER BUNDLE: Intel 4790K, Gigabyte Z97X-Gaming 7, Kingston 16GB 2400MHz Kit, Superflower 1000W Platinum PSU & FREE STUFF!! **£50 SAVING** £591.92
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £124.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £102.98
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £57.98
1 x Creative Sound Blaster Z High Performance Gaming Sound Card - OEM (30SB150200000) £49.99
1 x Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps £6.98
Total : £1,024.85 (includes shipping : ).
YOUR BASKET
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
Total : £74.99 (includes shipping : ).
would be running the gpu on air and i'm new to pc so i'd mess around with overclocking but it's not a deal breaker if the cards not the best ocer
then would just need recommending a non-reference 780ti, im just getting into pc gaming really so sorry if its a silly question as i assume they are all good but dont want to make a mistake on the gpu.
reason im going with the 1000w psu is i will be sling the cards before the year is out,
cheers for any help lads.
Perhaps the one with an 8 instead of a 7 at the beginning should be considered as stocks are being cleared.
Titans don't have £200 shaved off the price for nowt.;)
