Hello!
I was wondering what would be the best place to put my CPU heat sensor on a socket LGA775 motherboard that gives the most accurate readings??? Would taping the CPU heat sensor lead inside of the socket, at the side of the cpu, and then close the socket plate/lid down be best or would it be best if i just taped the sensor in middle of my heat sink???
Thank you for responding.
