What is the Best Thermal Paste?
MX-4s are popular these days. Use them myself and they're ok i guess, does the job.
Stulid made a thread comparing a number of thermal paste if you want to read up on it. It's actually in this same forum section at the top^^^
MX-4 isn't even as good as MX-3. Gelid GC-Extreme is also not as good as MX-3. Thermalright Chillfactor 3 is where it's at (cheap too)!
The best is actually Coollaboratory Liquid Ultra but it can be a pain to clean off unless you're not planning to remove your cooler often.
I've started using IC Diamond - it's unspreadable, but the idea is to let the component spread the paste out for you anyways. Pain in the ass to clean up but if you're not going to be switching out heat sinks or blocks much then I don't see any problem.
