- 8 Oct 2006
Hey,
I am going to part-ex my Wii for a 360 next week, which is pretty exciting. Although we have a nice 42" Panasonic plasma at home, at uni I would like to keep the 360 in my room to use on my pc monitor and 2.1 speakers.
Equipment List:
XBox 360 (60GB premium version).
Desktop PC with Soundblaster Audigy 2ZS Platinum soundcard (so I can run optical and/or composite sound sources through to my speakers with little/no latency).
HP w19 (19" widescreen LCD monitor with 1440x900 resolution, one DVI input and one VGA input
- The most obvious solution is to get an HDMI-DVI cable and run this between the 360 and monitor. Would using an HDMI cable with a DVI convertor make any difference here (it would be cheaper than buying a seperate HDMI cable for when I take it home).
- The other solution is the official Microsoft VGA cable.
I feel more inclined to go with the first option, but does anyone know what kind of resolution options will be offered? Will I be able to run my 360 in any kind of HD on my monitor?
ALSO: Now that all 360s come with HDMI as standard, am I correct in thinking the only incentive for purchasing an elite is the bigger hard drive?
Is the actual HDMI outputted image and machine performance otherwise identical to a 60GB version?
Thanks very much,
Alex
Equipment List:
Thanks very much,
Alex
