10 Jan 2011 at 18:45 #1 engstrom0304 engstrom0304 Associate Joined 5 Apr 2008 Posts 1,526 Hi anyone know (or have an 80mm fan to check) what the hole spacing is for a 80mm fan ... i think it is 60mm but im not sure?? Thanks Tim
10 Jan 2011 at 19:49 #2 ms2010 ms2010 Associate Joined 24 Feb 2010 Posts 171 Funny, couldn't find a fan that small until after I found this thread on another forum http://forums.bit-tech.net/showthread.php?t=154188 Going off the PDF in that thread its 71.5mm between the holes, which I then verified when I found an 80mm fan http://hatak.de/fileadmin/documents/axial_fans_a4.pdf
10 Jan 2011 at 19:52 #3 engstrom0304 engstrom0304 Associate OP Joined 5 Apr 2008 Posts 1,526 ms2010 said: Funny, couldn't find a fan that small until after I found this thread on another forum http://forums.bit-tech.net/showthread.php?t=154188 Going off the PDF in that thread its 71.5mm between the holes, which I then verified when I found an 80mm fan http://hatak.de/fileadmin/documents/axial_fans_a4.pdf Click to expand... Thanks a lot!! Exactly what i needed!
10 Jan 2011 at 20:08 #4 ms2010 ms2010 Associate Joined 24 Feb 2010 Posts 171 No problem, Happy to help
