I can't seem to find a definitive answer to this, but I want to ask only between hybrid AIO coolers and air coolers (I don't want to go a full custom watercooling set up)
Hybrid AIO solutions I thought would be ideal, but I understand they're not totally silent? There is still a fan, and you also get noise from the pump? I've never heard one so have no idea
For air cooling the ACX top down fans are the best and quitest I believe? But, I want to have SLI as an option, so 2 of these aren't the best compared to exahaust fans.
At the moment I'm using 2 reference exhaust 780Ti in SLI. To keep temps down the fans have to go quite high, and I find it too loud. I want some peace, so what's the best solution???
If I keep my 780Tis I'm thinking of getting the corsair n780 brackets and a couple of corsair H55s. If I get new card(s) likely 980TI, what would you buy in terms of cooling style?
