what is this and how do i get rid of it?
Hmmm, strange one - if you have windows restore switched on within vista, i'd rollback a couple of snapshots and see whether it's attributable to something you've installed (inadvertently or otherwise).
it isn't launchy - that looks different. don't use system restore.
i can't remember installing anything immediately before this occurred.
thanks
Looks a lot like Launchy, but without any text.
Take a peek into your Programs in Control Panel.
I shouldn't use System Restore though, I always find it to be the quick but not necessarily the best option.
i got rid of it by pressing the red X in the top right.
might not work for you though
...........did you look at the screenshot? im not being retarded and asking how to close a window. it is a blank window with no title and no buttons, it won't minimise and if i right click on the task bar icon of it, no menu is displayed.
lol soz i was just being silly
btw did u try ctrl alt esc/del or whatever it is for vista ...to see if a process name comes up for it ?
maybe help identify it.....or maybe run process monitor
thanks for the suggestions. it has now just stopped on its own...
i did check in processes to see if there was something that jumped out at me, but nothing abnormal.
oh well, i guess these things happen!
