Oh I thought they were talking about Zinsser Mould Killer. We will need to use a different paint to match the rest of the room.H+G is a mould spray and Zinsser is a paint. Clean up with the spray and repaint with the Zinsser and try to get a bit more airflow in the room (eg trickle vents) or dehumidifier.
To be fair, there hasn't been any noticeable condensation at all on the walls. But will look into it.Condensation issue. Cold, outside wall. Warm air inside condensing on cold surface.
Yeah but I can't use their paint as it won't match.
I've used Owatrol VC175 in the past. I can't comment on the effectiveness beyond saying the mould never returned where I used it. Saying that I believe mould will eventually return regardless of what you do if the conditions are damp enough.Yeah but I can't use their paint as it won't match.
